The best feeling ever!!!!
Does the spacer size change with different mods or does it matter? Where should I look for spacers?
i think i talked to you on the phone the other day, check your wheel mount surface measurement and then the H1s are 7.25 backspace. it depends on how much you want the tires to stick out. with 4 inches of BS on the wheels is pretty common and looks pretty good in my opinion. so with a 3 inch front spacer you would hace basically a 4.25 inch BS look.
