Depends on if you want to cut the fenders or not. With 4 inches you can fit 33's for sure with out rubbing. 35's will fit but they will rub so you may need to do some minor trimming. This also depends on the width of the tire and rim size.
Now if you wanna do some then you can fit whatever size you want.
All that being said, check out the search feature, this has been covered several times in the past.
My stock 90 runs 33's with just minor rubbing of the inner wheel well on the back when twisted up. My built 90 runs 37's with 3" of lift and no rubbing.
Thanks for the info,and I thought this topic has been talked about before.Sorry if I repeat some questions,I'm pretty new hear,and I'll search a little more before I post.
i had 33s for a while on my blazer, ran stock susp, 2", and 7"...rubbed no matter how much lift i had, but i had to try hard to get it to rub with 7". Lots of people run 35s with 4", just trim up some, don't do anything too extreme and you will be fine. Im running 40s with 5" rt now, so you don't have to have a ton of lift to fit a decent sized tire.
