The Evil K5
A rescue and rebuild from midwest rust.
Here is where the K5 stands today:
Front brakes are done with some new outer bearings, calipers and lug studs/nuts. I'm eventually going to run these wagon wheels that I blasted and painted white. One had a nice surprise on the inside rim edge. Me and my poor welding skills patched that and ground it down mostly ok looking. It will at least hold air. No pictures of the repair, just what the sand blasting revealed.
What I'm fighting now is these rear wheels. They are stuuuuck like you wouldn't believe. Finally got the passenger rear off after a ton of work, heat, and PB Blaster. Here is what finally gave me the leverage:
That is a 12 foot 4x4 and it barely took it off. I broke one strap doing this. The driver side appears to be even worse. I'm at a loss. I don't know what I can do to get more leverage to get this off. Any ideas?20261019_164904.jpg
That is a 12 foot 4x4 and it barely took it off. I broke one strap doing this. The driver side appears to be even worse. I'm at a loss. I don't know what I can do to get more leverage to get this off. Any ideas?View attachment 537207
Leverage is not the way.
I used a big sledgehammer on the tire because I was saving the wheels
Those look to be rally wheels. i had one stuck a while back and used the threaded hole for the center cap to help free them up. if i remember correctly they were threaded 5/16-18 threaded a bolt in and tightened it to help break the wheel free of the drum
This is a good idea. I'll run a thread chaser through these first and try that out. Thanks!
Old timer taught me a trick for stuck dually wheels. Loosen the lug nuts about 1/8" away from the rim and drive in tight circles slowly in both directions. Usually the side load will pop them loose. As long as you have room at the house, you could go to a parking lot and just take a lug wrench with you to loosen and retighten.
I've been hesitant to try this because I'm trying to do a brake job and the other wheels are already off. If the suggestion above doesn't work I think this will be my next attempt.
Yeah it only works if you are able to drive it and not tore down for other stuff.
Finally got the stubborn wheel off. I stripped out every one of the threaded holes on the wheel for the center cap. Then drilled and tapped one to a bigger size and stripped that one out as well. Went and bought the biggest hammer Menard's had and had sweet success.
Told you.
I even did that on my big rig wheels plenty of times
Finally back on the ground. New brake hardware in the front, new brake cylinders in the back and only broke 3 of the 4 brake lines! This brake job took like 20+ hours. And I still need to bleed the back brakes...20261031_140723.jpg20261103_164607.jpg20261103_164655.jpg
I'm contemplating rolling this inside for the winter to pick away at it whenever I have time. I need to pull the HVAC since I'm pretty sure the heater core is leaking.
