euzoa
Well, as some of you may have seen I picked up an 83 k10 4 speed, in very very rough shape (It was a birthday present to myself and I'm sick of playing xbox while I wait to ship my jimmy out). it was relatively cheap, I now have a much better idea how to do things and I actually have extra money.I plan to get it back into road legal condition before I make any other big changes, so to get my thoughts in order, here is what I need/intend to do for now
1)install new column (old one has the ignition broken out of it and a new one came with the truck)
2) install new cluster(old one is smashed up, though the bezel is actually ok
3) unfu...fix the behind the dash wiring (its been owned by kids for a long time)
4) new hd clutch and flywheel (adjuster is at its limits, and flywheel doesnt cost much extra)
5)front drive shaft( its whole, but the kid took it out in the mud one last time, and now it is hanging on by 2 bolts, resting on the cross-member compared to when I looked at it
6) the rear shocks are completely unhooked, I haven't checked the mounts out yet
7)the front grille and turn signal housings are smashed, I'm thinking a pierced steel planking front grill if I can find a good way to mount it and make it look clean.
8) only the head lights work, I need to troubleshoot them, hopefully it will be something I find in the cab
9) parking brake cable is broken
10) brakes
11) the door pins and bushings are VERY bad
12) rebuild/reseal the tcase (if just the rear seal is leaking I will simply replace it, if I have to split the case I will rebuild it)
The problem I've had in the past is trying to do to much at once, so i am going to go after 1 or 2 problems at a time, focusing on drivability issues
10) brakes
