Dodge problems.....
I think it's got to be hooked up the same way the coolant flows.
I’ll look at it again one day for sure.
Dodge problems.....
This one says it pumps through convection not mechanically. Idk I think I'll just run the one I have rather than spending money on a different one.This one is an actual pump, it moves the coolant just like the water pump. It will get hot enough to open the thermostat and everything.
Here's a better link.
https://www.amazon.com/Kats-13100-Aluminum-Circulating-Heater/dp/B000BO8X9K
Well shit, I guess I need to walk out to the big block and see what the hell I put on my truck 13 years ago. Lol, but it 15 degrees out.... Anyways I thought what I linked was it. Maybe not. I know mine pumps coolant as it's annoyingly loud when plugged in. I bought it at a Napa in 2005...This one says it pumps through convection not mechanically. Idk I think I'll just run the one I have rather than spending money on a different one.
Today I wired the exhaust heat riser valve closed and it seemed to help but it wasn't perfect. I will have to mess with it some more later.
This sounds correct to me.Wait so the 1/8" is from the tip of flywheel gear tooth to shaft of starter? The instructions say the 1/8" is when the gears are meshed it should be from the tip of one of the teeth to the root/base of one of the opposite.
Without any shims the starter gear couldn't even engage, too much interference. Same with 2 shims. It took 4 shims to even get the gears to mesh and 6 for that 1/8" clearance.
I have no idea. The engine is some kind of older GM crate engine. I haven't checked the block number or anything who knows if it's been rebuilt but from the outside it appears all factory.makes a guy think if the block was line honed real heavy on a rebuild to shove the crank that far up the block to throw off the gear mesh like that . . . or i got no clue ?
Back home every engine I had needed shims to make it work.I have no idea. The engine is some kind of older GM crate engine. I haven't checked the block number or anything who knows if it's been rebuilt but from the outside it appears all factory.
