1969 Chevy Blazer (AKA The “Anti Prius”), Stroked 383, TH400, Twin sticked 205, Trussed Dana 44 (Front) , Trussed 12 Bolt (Rear) with a Eaton Tru Track (Soft Locker), 410 gearing, 5” total lift on Custom ORD springs (Stock Lengths), Front-4” lift spring with 1” zero rate, Rear-4” ORD shackle flip with 1” zero rate, ORD 2 link traction bar, 33” BFG All Terrains with steel truck rallies painted green, Coyote internal bead locks, Both ORD weld-on and bolt–on steering box braces, Fox 14” x 2.5” triple bypass with remote reservoirs on all 4 corners, Fox 2”x 2.5” Air Bump Stops on all 4 corners, PRP seats with 5 point Crow Harnesses for 5 people, Full cage 8 points to the frame and 6 points to the cab, 21 gal Aluminum fuel cell , 7 – 7” HID’s and 2- 8” double row LED lights, Holley Sniper EFI system
