Did you ever lift this? I forgot what you've done
Yes. 3" EZ-ride springs in the front (not HD springs). Rear got new stock-height 1850# springs from General Spring of Kansas City, plus 3" welded blocks. Front shocks converted to use Ford-style shock towers. Steering arm has been changed, and I have a set of sway bar disconnects. Otherwise it's all stock geometry.
I stuck with the soft springs because of this truck's intended purpose. I can always add leaves or airbags later, if needs change. After a couple years of wheeling and hauling, I don't think I will need to.
