The Great Smaug
A quick recap of our adventure here 2 years ago (read the rest of the story here):
Yooper Trip is in the books, and we are back home safely. The fuel line worked, the new brake fitting held (despite plenty of bouncing), and I left the dash bezel at home because I still haven't taken the time to trace the 24V voltmeter problem. The speedometer broke the night before we took off, and the issue is inside the transfer case. :doah: So we went without this time, driving off of phone GPS speed estimates.
We drove about 850 miles (guessing due to the freshly broken speedometer), and the truck had zero mechanical issues on the road. With one large caveat. I dumped the poor Grendel into a puddle, and took on water for a few minutes until getting winched out by my traveling buddy.
20170817_132338-jpg.241381
Water poured in through weight-reducing holes in the floor and non-existent door seals. Pictures were not a priority, but we grabbed a few blurry ones while waiting for Adam to spool out his winch. Outside, water covered almost all of the rear bumper and buried both the headlights. Inside, it rose gradually until the driver's seat was submerged and the water started to flow over the tranny hump where the shifters are, and also onto the bed floor where the camping gear was located. :doah: The passenger side had less water but still soaked the bottom of the seat before we reached dry land.
imgp5325-jpg.241532
imgp5327-jpg.241533
imgp5321-jpg.241538
I will admit to getting slightly impatient as I saw myself turning into a mermaid. But it's hard to complain when you have a friendly tow strap bailing out your own stupidity.
Thankfully, most of the gear up on the bed floor stayed dry, and most of the gear in the front didn't matter too much. Aside from my paper maps, of course. :rolleyes:
The engine stayed running, and once we got back to shore everything looked fine and functioned normally. After a minute or two of having no belt accessories, the belt squealed back into life and we were back in business. I have never imagined being so glad to hear a belt squeal!
imgp5330-jpg.241534
I still can't figure out how the intake kept dry. It certainly couldn't have done so if I had been running the stock air tube running down to the core support.
imgp5331-jpg.241535
Pictures of the offending puddle. It was shallow on both sides with a transverse gorge that swallowed the truck quickly, one axle at a time. No current during this adventure, but it clearly hadn't always been so calm.
After extraction:
20170817_132502-jpg.241546
imgp5328-jpg.241547
Then Adam pointed out that the puddle had a bypass. It wasn't a great bypass, but it wasn't as soggy as the puddle, so I drove around the water instead of through it. :rolleyes:
20170817_132931-jpg.241548
When I first opened my door to let the water out, I tried to catch the various baby clothes, diapers, tow straps, etc. that flowed out of the cabin. But I failed to catch my water bottle (the white floaty thing in that last picture). So it floated around in the puddle for a while. Adam eventually fished it out, so I consider the bottle a survivor as well as the truck.
After surveying the puddles, we decide that fording 20" of water probably isn't going to sit well with all of the UPO guys (not everybody is lifted, last year we had a stock Outback tagging along). 20" of water didn't sit so well with me, either. I did want revenge, but have been a little gun-shy this year after the events of the last 2 years. While the intention is to lead the group through, we decide we need to scout an easier backup route in preparation for the inevitable complaint. So...reluctantly...we turned around again and I did not wind up going through the puddle. We still didn't know where we wanted to camp, so we had to keep moving.
We found several spots we didn't really like, and wound up utilizing an abandoned campground. It was pretty nice, I'm not sure why it was abandoned. :dunno:
More blueberries. Because of course there are more blueberries.
The next morning we packed up and checked out a small dam since we were nearby.
We headed out toward Vermillion, aiming to run Wildcat road. When we got there, however, we found the road mostly blocked:
A group of students from downstate had rented an RV and headed up to the woods. If I understood correctly, they were heading out toward Vermillion, looking for a campground. Somehow they thought they'd pull off into the woods and camp on the side of this road. The road was good enough, but the side track they pulled into was deep, loose sand and also had a downhill slope. GVWR was 12,500 pounds, and they had it buried up to the frame rails. I figured we had no chance of extracting them, but we decided to give it a try. First Luke set up his winch, which simply moved his truck rather than the target. I don't have a winch (yet?), but I hooked up my tow strap so we could both pull together. "Together" is a pretty loose term, given the radical difference in our pulling speeds. But why not give it a try?
To my huge surprise, we pulled it out. And really, Luke's winch went slack after a couple inches. So my 5500# Suburban wound up doing most of the work. Maybe we should have tried 2 tow straps so we could both pull? :dunno:
Regardless, it popped free and we pulled it back to the center of the road. Somehow the camera only recorded the beginning and end of the extraction. :doah:
View media item 37264
View media item 37265
But getting it onto the road was only the first piece. Then we hooked my strap to the front, so Luke could pull the front end back onto the road.
This road had about 1/2" of loose sand on top of firm sand, but the side route was loose enough to swallow such a heavy elephant.
The camper was now back to facing its original direction, heading away from pavement and further into the woods. Vermillion Road heads basically nowhere aside from Vermillion (an abandoned Life Saving Station and swampy nature preserve, with no services or campgrounds) and the puddles we just visited. The driver said he wanted to follow us. At which point I had to break it to him that the terrible sandpit he sunk in was just the gatekeeper to the trail we were looking to ride, and that the sand would get deeper and the trees tighter within a few miles. His eyes swelled a bit, and I told him he was best off turning around. I wound up backing up the camper a hundred feet or so to a different turnoff. It was still questionable, but I managed to get it turned around without requiring any more tow straps. Which is good, it would have taken six miles of backing up to reach the nearest hard surface.
We ran Wildcat along the shore and wound our way back to Paradise (see pictures from 2017 trip, it hasn't changed much). Obligatory picture of the Paradise Bear (grainy, I know :rolleyes:):
From there we pounded pavement down to Brimley, to scout the next campsite.
This was also an abandoned campground, with a pretty beach.
We also had a teachable moment when we encountered good berries and bad berries growing side by side. It must not have stuck, because I still wound up with one kid complaining of a tummy ache. :rolleyes: :haha:
This campsite was a bust. It looked great, but was clearly posted as USFS land, no camping allowed. Even though it clearly looked like a (former) campground. :(
So we decided we'd use a different spot, and concluded our scouting run. Luke headed home (since we were on the East end of the peninsula), while we took the opportunity to check another lighthouse off the list: Point Iroquois Lighthouse.
4th order lens. Pretty standard fare on the great lakes, but it's still so cool to look at!
Across the water from here is Canada.
When we had seen our fill of Canadia, we pounded pavement the 4 hours back home.
We didn't have to help that RV. We could have broken something and eventually they would have gotten some kind of big $ wrecker tug. For all we knew they might just get stuck again. But it seemed like the right thing to do, and an interesting diversion since the day was young.
When we first showed up I thought "couldn't help" meant it was an insurance or liability thing, then realized they thought we weren't able to help since some Toyota had already come by and tugged on them (in the wrong direction). I said "What's that got to do with us? We have 2 heavy Chevys "
While trying to get the RV turned around it was obvious spotting the driver just wasn't going to be enough, so I explained politely that he needed to let one of us drive. He seemed elated at this proposal!
Edit: oh yeah, I got to amuse myself by crawling the K5 through the ruts they dug, shrugging my shoulders and telling them driving in sand is easy.
Fair points. They may have gotten stuck again later, we never would have known. I did tell them to stay on the straight and narrow until they reached pavement, and not to leave it anymore.
I don't know if you caught the look on his face when I said we were turning off the road there anyways. He took a look at our side of the route (steeper and softer than where he had turned off) and he suddenly lost his desire to follow us back to civilization. :haha: :rotfl:
It's good karma to help out others that might get in over their head. We helped some guys on our last outing with a flat on a trail. Years ago Larry and I have run across an RV that went a little too far over on a dirt road to let someone pass and got stuck in the ditch. A couple of quick tugs with one of our trucks got it out. As it turned out it was a bunch of guys out from St. Louis to ride MX bikes in the mountains and came loaded with Budwiser. Without even asking they were so grateful they gave us a case of suds to have for helping them out.
It's always cool to see your trip reports since they are the opposite of what I usually see on mine. Keep it up guys.
I didn't know he wanted to follow us. :haha:Probably so we could pull him again. Probably 1/3 of the road we took was softer than where he was stuck and that's more than 10 miles! I guess he didn't realize what he was already on was the main road back to town. Would have been interesting to see him meet traffic in those soft spots in the road on the way back. But we only had 4 tires each and he had 6, so what was his problem?
Opposite, in that you break axle shafts and I break engines? ;) :haha:
I mean...thanks!
:popcorn:
Yeah, he seemed shook up about the whole thing. Definitely wasn't comfortable getting back to pavement on his own, even on the main road. Funny he got stuck exactly where we wanted to turn off anyways. Made it easy to explain where we were going. :rotfl:
With the scouting trip finished up, we next headed back Up Nordt for the group trip. This year our plans got repeatedly jumbled due to inadequate communications planning. Starting with the very first meetup spot. The first trail segment had the group driving the the direction of our house. Rather than starting early, driving to the trailhead, and then backtracking, we decided to meet them an hour or so into their route, at their first real point of interest.
Beautiful Lake Michigan, under a clear blue sky (or at least, what passes for clear around here).
Turned off the pavement and picked up the gravel.
Turned off the gravel and picked up some dirt.
We arrived at this small scramble area. It's kinda neat, but nobody else was there yet. With no phone service, and being hopelessly outside of CB range, we opted to sit down and have a picnic.
After an hour or so we got bored and wandered down into the valley.
The burb, of course, is a firm believer in its open door policy.
And so we sat. And waited.
Eventually the group thundered into the clearing. Turns out an early breakdown had slowed their departure considerably. In hindsight, we could have driven up there, wheeled the first segment, and still have spent less time. But we didn't know that, and we did enjoy our picnic.
Disclaimer - I had neither a dedicated photographer nor a good camera along for this trip.
Some folks scrambled, but overall the group seemed eager to make up the lost time.
My favorite Gambler-racing Toyota came back again. Last year it had pretty bad blow-by, and a mistuned carburetor. This year it had a fresh rebuild, but approximately zero miles on a brand new EFI installation. At the beginning of the trip I think it had worse driveability than last year. But it got better along the route. I've never been a 4Runner fan, but that one seems cool somehow.
Once we all had taken our turns at the hill climb, we circled the wagons and headed out. This segment was full of dust.
And U-turns. :rolleyes:
So the vehicle order kept changing.
And did I mention dust yet?
Second POI this time was Kitch-iti-kipi. The Big Spring, with some pretty cool water.
And a raft full of tourists.
And a hole placed strategically in the middle, so you can look down into the water and watch the fish and the submerged forest float by.
If you look past the glare, there's a whole forest preserved down there. @Blue85, these trees must not have always been submerged...did the trees fall in, or is the water line higher than it used to be? :dunno:
And then, as the convoy rolled out, I turned the key and was rewarded with a dead solenoid click. :doah: I clicked it a few more times and it roared to life. :dunno:
As a test, I shut the engine off at highway speed and tried to start it. Again, no dice (but I could pop the clutch easily thanks to my speed). So it's not just a freak occurrence.
Hmm...heading into the woods, with a failing starter motor. With 500 more miles to go. Zero parts stores along the route, and we're heading further away from the ones behind us. 6.2 diesel engines are hard to start on a good day, they do not tolerate weak starters.
Tune in next time to find out!
:popcorn:
You're not fooling anyone with your claims of an underwater forest. We can see it's the reflection of the trees on the shore. :D
I've heard that the minerals in the water help preserve the fallen timber, but I'm sure the cold water also helps. Some of the trees have clearly been claimed by the sides of the pond sinking in, but the pond has hardly grown over the decades. I think a lot of them are just trees that have fallen in. This spring has been like this for as long as anybody knows. You would think if the main outlet of Indian Lake was dammed (into the Manistique River) that 10,000 gallons a minute would bring the water levels up pretty quickly, but I don't know much about watershed and if that's even a large portion of what the river is dumping into Lake Michigan. Apparently it was used as a dump back in the lumber days, so I've always wondered how they got it cleaned out. Maybe it was mostly biodegradable stuff, not all the plastic trash like we have today?
https://upsupply.co/places/kitch-iti-kipi
https://schs.cityofmanistique.org/the-history-of-kitchi-tiki-pi-big-spring/
