the np208 on the back of my 465
This. I've successfully used rafters to unload air compressors and engines. I like using a racket strap or come-along for adjustability. That should give you the third hand you need.
David
Trans came out to do clutch, I removed the bell housing and reinstalled as a full unit, but i didnt know you were doing this with a 4500
This whole statement is the essence of most of my driveway excursions.For this situation, I have ordered a cherry picker from hazard fraught tools. Should make life a bunch easier. All I gotta do is rig up a better plywood floor to keep the wheels out of the sand.
I think this solution will increase the safety level a bunch.![]()
I knew. But I also keep getting your builds mixed up. You have a lot of tranny woes...
Can I have a couple of them?See my conundrum? I have too many hoists now.
That's ok with me, as long as they get here.Can I watch your brother try to put them in his trunk?!![]()
He put that cradle in his trunk. That's a big cradle, but obviously it's a bigger trunk. He and I laughed about it for a bit. After we loaded it, we then discussed how many bodies would fit in it.
Yep, drum set was in the rear seat. Trunk was wide open. The drum set it actually what sparked our 3 hour conversation.
