I do it the same way Martin does it, slow and deliberate, because it'll literally just pop in once you get the parts lined up.
Did you grease the splines and snout of the input shaft?
I usually slam them in by hand. The jack is just there to help.
One hand turning the output shaft, while using the other to move it around. You do have it in gear right?
Martin
Yes it's greased, yes it's in gear, and yes, I've turned the shaft while inserting it. It's pretty easy to get it engaged with the clutch disc (after which I cannot turn the shaft anymore), it's getting the pilot bearing lined up that 's vexing me.
Quick question, did you test the pilot bearing on the shaft before installing it? I have had that issue before where the pilot bearing was not correct and there was no way it would fit on the trans. Just a thought
Maybe this was asked but did you use one of these to line up the clutch on the flywheel?
Ok lol jusssst checkin. Splines are the same on the clutch disk too?Yep. Plastic stick thingy inserts without issue. Read into that whatever you will.
Naaaaaa... He will get itThis is going to go south, quick...![]()
I hate that feeling.My heart just skipped a beat... I was thinking about mine and for a second I thought I forgot my throw out bearing!
