Really? It should eliminate the ~3" of spacer that I had to add to the middle, and the later ones hump upward on the driver side, so the T-case skid plate should be the only part hanging down. Right? Seems like it's better for 2 of the 3 segments.![]()
Don't worry about the oil leak, it's an automatic rust proofer![]()
And today Wifey spotted a pile of black engine oil underneath this truck. All under the hood is covered in oil, it looks like the fan has been flinging it everywhere. I'm down 1/2 a quart (which doesn't seem even close to reasonable given how much oil is all over the engine compartment). My guess is that the oil cooler line is leaking in front of the fan, but I had guests show up and I don't feel like heading out there to check into it at 0 degrees tonight. I'll look it over in the daylight.
Not sure what the severity is yet, but this counts as my official first mechanical issue.
I had a oil cooler line develop a pinhole leak. The post mortem after showed a small area of the aluminum line that looked like it had been stray arced with a stick welder. still not sure what happened originally...but that's where the pinhole was. The leak started on a wheeling trip. I had my 13 year old daughter with me, and with no warning I had big orange flames trying to squeeze through the gap between the pass fender and the hood. Things were very exciting for 30 seconds or so until I shut it off...
We spent about 45 minutes patching the line up so i could get it home. JB weld and electrical shrink tube did the trick. I guess the pinhole was aimed directly at the alternator and a spark lit the oil mist.
I think you'll love the DD duty. I'm not driving mine every day, but at least once or twice a week. It's those DD road miles that will build up the trust level in the rig and get your comfort up to stretch it's legs on some longer drives later.
), so I'll prolly pull the column out and fix both problems when the weather warms up again.
Ahh, EFI for the win. The K5.3 started this morning at 15 degrees on first hit of the starter. Had that been my 75 with the 350 and Q-jet I'd would have been out there for 30 minutes trying to get it to cough to life. I can imagine an oil burner being pain to get lit off without help at low temps.
Or I wasn't able to run the plugs and the camera simultaneously, which sounds more plausible.Just let off the throttle.
Martin
Great report Campy. DD duty is great for shaking down a rig. Drove mine for two weeks before Christmas, not one issue. Took it on our snow run, again no issues. Last weekend got a call from my Wrecker driver who got the truck stuck near where we went snow wheeling. Hopped in mine to go pull him out. Got a half hour away from my house and the sob stalled like I hit the key. No stumble no warning. A guy following me stopped and pulled me to the top of the hill I was on.
It would crank, not start. No fuel pump. Used a chunk of wire to the test lead on the fuel pump relay, pump would work but it still wouldn't start. Checked for spark, none. Suspect the ECM is offline. After talking with Larry on the phone I rechecked the fuses by pulling them and not just checking for power with a test light. Found the 10 amp ECM b fuse popped. Didn't have any spares, so I swapped in my radio fuse. Fired right up. Still not sure what caused it to pop, but I'll need to drive it more to see if I can make it happen. Don't need this on the trail in the desert.
Do you travel with a multimeter? It'd be worth measuring the current draw under normal conditions. Just to see if it's close to the threshold.![]()
I don't ordinarily run with a meter in the truck. Testing current requires putting the meter in line on the circuit. Kind of hard to do on the roadside. I might need to pick up a fuse buddy that I can plug into the fuse spot and be able to monitor current draw without the meter.
