The headache build..
I also made my power steering pump bracket. I assumed the bolt pattern of a TC style pump would have a 80mm even bcd. I was wrong. The hole to the side is off by 2mm.
I have to somehow fix that, make spacers to line the belt up and mount the pump to the motor plate.
Just read through this thread. Very nice.
I loves me some FAT BLOCK!!
I'm on my second fabricator since I pissed off the first one when I told him to make a change.
Anyway, here are some cage progress pictures.
IMG950704_zpsqqphfacr.JPG IMG950703_zpsahq1kicv.JPG IMG950702_zpsxxw0cpt0.JPG
I've requested to have straight door bars.
So those will be changed when I get more pictures.
IMG950766_zps9kc8rok0.JPG IMG_0773_zpslq9fa42l.JPG IMG950770_zpst4nvtqxj.JPG
bitchin'!
Do you plan to have this thing out on the sand next season?
Looks good. Glad to see this thing finally getting a cage.
When you took me for a ride out in the dunes a couple years ago all I was thinking was... we're going stupid fast... and I wish there were a cage around me. :)
surely those corner gussets will slice into the tube and ultimately kill you to death!
Nicely coming together, are you having rear seating?
Agreed! :waytogo:
I am curious to see how they get full perimeter welds in all those tight spots. Maybe I will learn some new tricks? :dunno:
-G
He hasn't finished welding yet, but he said to use a reduced diameter nozzle. He had one on back order for over a month. He is getting tired of waiting, so he is going to cut one down in his lathe.
Not much to update on current progress, but I've fix a few photos in the first couple of pages, but here a picture I just found of the old blazer.096.JPG
There is a thread on yellow bullet about douchebags posing with their cars. It seems the qualification was somebody posing by their cars.
I should be working on fab, but I'm trying to fit ten pound of shit in one drawing.
I need to add,
BLK- grounds, horn switch
BR- Sw to running lights
Tan- low beams, purge
PNK- fan 2, retard 1
R- ignition, light power
ORG- fan 1, SW panel power, transbrake/NSS
YEL- fuel pump, rear left turn
LtGRN- high beams, reverse lights
GRN- horn, rear right turn, reverse light switch
LtBLU- water pump, front left turn, roll control
BLU- transbrake, frount right turn, Nos Arm?
PPL- starter, retard 2
GRA- coolant switch, tach signal
WHT- brake lights
LtGRN/BLK- data logger power
WHT/BLU- data logger record start
