This thread is for the general discussion of the Item The Kid and his K5. Please add to the discussion here.
The turn signals both running when you turn one side on is an indicator of a bad ground.Could use some quick advice on a couple of my many wiring mysteries:
- Noticed somebody clipped the wires to my dome light in the past. I am having issues thinking on why they were cut. Will I be taking any risk by splicing the wires back together for the time being?
- My taillights are only receiving 6v. The break lights work fine. The left turn signal works fine. The right blinker activates both turn signals. I have searched for where it is dropping the voltage on the wire from the taillights to under the dash. It has clearly been messed with a number of years ago as I found a household wire nut tucked up by the gas tank but current is still running through it. Any advice on where to start probing with a multimeter and how to think about that sort of issue?
I am saving up some cash to re-wire the whole car, but having taillights lets me keep driving it at night for the meantime.
Thanks,
Liam
check all the bulb elements. Sometimes when one element breaks it connects to other in the 1157 type bulb, this back feeds the second circuit and lights the other side. could be front or rear. Give any trailer wiring a thorough inspection. tail and brake wiring should uninterrupted loom from firewall bulkhead connector to rear bumper. the bulkhead connector could be the source of resistance, dropping the voltage to 6v.Could use some quick advice on a couple of my many wiring mysteries:
Thanks,
Liam
Thank you for that knowledge!Not sure when the timing belt was last changed or if it has been
@Liamking01
the Chevrolet 305 uses a timing chain; not a belt. it is not a maintenance item like a Honda where replacement is recommended at so many miles
also, just so you know; your front bumper is correct for 73-80; 81 up uses a different one
Oof yeah I’m seeing that now. Gonna have to order that one to the parts store. Is there a brand to buy that’s fairly rigid? Or are they all the same?They are riveted at the back of the pins. I have not seen one rebuilt.
