dieselndixie
So, I have the leak, It doesnt seem to be leaking from the seal at all. Is the shaft supposed to be out that far? It looks like it coming from inside the slip yoke.
Now, I added more trans fluid to my transmission because mine was low...then went wheeling. got back, and the leak was worse than it had been before but hard to tell where it was all coming from. Was it because I added fluid to the trans, and maybe the seal from trans to tcase is bad? or just coincidence.
Keep in mind when you are suggesting fixes, that I plan on installing a 4" lift very soon if that changes anything. Plus I am open to both temporary fixes and permanent fixes.
