just a little 5min skim off with the wire wheel on the grinder . then 1 spot lower left i hit 1min with 40grit sand flapper wheel . these will clean up real good for tables .
how i am thinking of building my frame work to hold the slab .
hope to whip up a frame for the table this weekend possibly .
even stoped at the welding supply store and got a fresh bottle of c-25 mix for the welder .
thinking of having just the top of my plate media blasted to bare metal so I can start clean and fresh . even tho its a new sheet its been sitting a lot before I got it and has heavyish surface rust .
Well it's been a bit but winter coming and I am NOT plowing snow around them again . Got steel for frame work and ready to build them now . . . . Time to get it done !
So the 1 4x8 sheet is in the shop and on the lift . . And yes there is a small amount of sag in the middle
Using what I got cheap and also its BEEFY and will add more weight to sit and not move when working .
10" c-channel 1/4" thick in the web . 20ft total @ 7ft x 2 and 3ft x 2 for the frame .
The legs are going to be 3x3x1/4 wall square tube . Some flat plate on bottom for feet . Then angle to lock them together and make a shelf mount and also use pallet jack to move them if need be.
Time to start cutting channel . Break time is over .
Got my end cuts done . 7ft x 3ft box size. Test fit went real good . Burned the box together and called it a day . Had to go help a friend unload a truck with locked up brakes . Then it was dinner time .
Next is 4 legs and feet . Then tie them in with angle iron for shelf and lift point for palette jack .
So far we are tipping the scale at 1,700 lbs and that's the plate and box only .
Well I knew the 2x2x3/16 angle I got was to thin . . So I went back to my HEAVY metal guy for another round . Well I left with the last of his new cut scraps tonight . Pic already has 2 lengths removed from truck .
So I upgraded the lower shelf point and pallet jack pic point to 3x5x3/8 angle
Doing the 5inch tall face up and 3inch for the flat to set shelf in if I want .
Doing this got me to 1,950 lbs on paper of weight to this point. Still need to do the 12 2" receiver points on the frame 3 per side minimum . That should push me over the 1 TON total .
Just need to dress the weld points on the legs and burn in the angle and then do 4 mount tabs and drill & tap the plate. And were ready to flip and weld 4 feet on and. ....... DONE !
Yes iij ts taking a bit but the first 1 always takes longer as we know .
Feet on . Set it on the floor first on feet . Then jacked up low corner to make top level . Tack welded all 4 corners and feet . Picked it back up and burned them on .
Just need to finish a few points and she will be 100% done .
