THE MAN CAVERN & MORE ...............
sweetk30
Back to play nice .
in the back of your brain
so this will start as a collection of threads from start point to current of this thread starting .
finding and buying : https://ck5.com/forums/threads/toda...-me-read-post-120-we-are-in-the-house.316892/
wood stove modify : https://ck5.com/forums/threads/24-inch-lift-kit-yet-functional.323361/
modine hot dawg heater : https://ck5.com/forums/threads/shop-heater-it-s-alive.323287/
work bench bling bling : https://ck5.com/forums/threads/little-bling-bling-in-the-shop-today.322961/
shop entrance awning : https://ck5.com/forums/threads/new-shop-entrance-awning.321492/
cheep shop storage : https://ck5.com/forums/threads/cheep-easy-shop-storage-project.321389/
refurb of shop lights : https://ck5.com/forums/threads/i-can-see-the-light-now-update-24-dammmmm.320974/
parts washer build : https://ck5.com/forums/threads/super-parts-washer-on-the-cheep-build-thread.289961/
band saw setup : https://ck5.com/forums/threads/milwaukee-port-a-band-swag-off-road-table-kit.320307/
hydro lift table : https://ck5.com/forums/threads/sweet-new-table-for-my-shop.320472/
air compressor : https://ck5.com/forums/threads/black-max-air-comp-help-update-post-5.318408/
Lincoln welder : https://ck5.com/forums/threads/fixed-lincoln-140c-welder-shield-gas-problem.318445/
shop wheel dollie modification : https://ck5.com/forums/threads/how-...problem-with-cheep-shop-wheel-dollies.328026/
the drill press : https://ck5.com/forums/threads/the-arm-breaker.328411/
the BIG tig welder : https://ck5.com/forums/threads/looking-for-a-new-welder-found-a-bigger-one-today.331559/
hypertherm powermax 45 xp plasma : https://ck5.com/forums/threads/what-the-heck-will-i-do-with-this-thing.331910/
snap-on tool box : https://ck5.com/forums/threads/new-snap-on-tool-box-build-up-updated-post-126.225524/
bt pallet jack : https://ck5.com/forums/threads/b-t-l-2300-pallet-jack-rebuild.336268/
20 ton harbor freight shop press setup : https://ck5.com/forums/threads/20-ton-hf-shop-press-mod-today.340021/
SKAT BLAST 960 media box & I.R. 2420n5 compressor deal : https://ck5.com/forums/threads/skat-blast-960-cabinet-and-i-r-air-comp-like-new.340166/
last 5-6 weeks solid I have been working on getting the shop cleaned / prepped / add in few items and get ready for major upgrade job .
did the wood stove mods / added the natural gas heater / added in a few extra goodys before the JOB . . .
then the 2 trucks and trailers showed up nov 9th 8am bright and early . I was up at 5am with a fire started for them to get the shop a little more warm .
the guys got right to it and had the whole place done by 4pm that day .
2" closed cell spray foam in attic to the drywall so the heat / cool stays in the shop now . also 1.5-1.75" on the 3 shop doors to make them do there job better .
last was a bunch of holes for wall fill try-pol foam in the walls .
the 1 shop door has the 4 holes in the lower panel for intake filters for the paint bay it is . I just framed them out with drip edge flashing and riveted to the door panel before foam so I have a nice box to set the filters in place .
foam on that door if I don't want to heat that bay when used for storage . or hold in heat for work .
next summer prob fix all the holes in the drywall from cavity fill . . . no biggy now tho . also trim down the high spots on the doors and cover with rolled aluminum flashing .
Sounds like a thorough job Brett!
I also dig the hood/awning idea!
so I found out why they tossed this unit . . . . .
some jack wagon stripped the threads clean out of the bushing the 3 handles go on .
the bearing was ready to drop out also .
and removing the bad bushing with threads all bound up on the shaft killed the shaft .
new shaft / bushing / bearing kit shipped 87 bucks .
I still did good I guess. . . :surepal:
I would say it's still a good deal. New is what 700 to 800 dollar range, + shipping?
The Surplus Center sells acme threaded shafting,but I dont see a listing for acme thread nuts to go with them..(weird!)..W.W. Grainger might sell them though...
I know you already ordered the parts,but if you need acme thread shafts for another project like a vise,etc,this is a good source to find some reasonably..Surplus Center
bolt in acme thread shaft 34 bucks.
and yes I know a new 7600 unit is big money as the 7400 model no longer for sale since updated .
I wont use it much but when I need it I will have it .
McMaster-Carr.....They might not be cheap, but they have a lot of different things......Plus they have one of the best sites out there.
Last month has been crazy around my place . Pulled old siding and fixed a few little problems . Put in 4 new windows that are more efficient and open . 2 new entry doors . Then we wrapped it and put left over new siding from house on the front and metal on the sides and back .
Upgraded security lighting on all 4 corners and full side yard now . Also a little extra BLUE for little something extra . Sure was a project as i had to move EVERYTHING away from shop i had collected from when we moved in in 11/2014 . But well worth it in the end .
Built a fence between shop and corner of property line point and matched it to there fence . But so we could still use it its mounted on a farm gate and a wheel on the end for support .
Next was my parking area behind the shop . It got a massive update with fabric and 50ton of crushed #2 stone and plate tampered in place . No more mowi g and sinking in to lawn .
Hauled it my self and empty i was 10,400 and was averaging this on the scale out of the local pit . The 3500-HD and 8.1/nv4500 combo didn't even complain with the weight . Just wish i had taller sides on the truck was all .
Averaged 2.5-3" of gravel on the pad . Plan is boarder it with railroad ties pinned in to the ground with rebar and wood chips to the woods from there for a clean look and less maintenance.
