one wall w/ the bathroom would work well for a slim mezzanine. lots o storage
I just got a liftmaster shaft drive, grabs the end of the shaft the springs are mounted on, however i live in Cali and everything after the fires a while back requires all sorts of safety junk, battery backup, etc so I've lagged at getting it all running. The deadbolt and release work fine though. It was really the only option in a low overhead situation, but I love how it clears up the overhead space.Man that is looking really good! I just read your whole build thread and it has turned out great with lots of room around your rv.
I do have a question, and I probably just overlooked it.
What brand and size doors did you go with? And are they insulated?
I'm going to go with sectional insulated doors in my shop, and probably liftmaster openers.
I think I mentioned it, but I am running the liftmaster jackshaft openers in my garage as well. The one thing I did have to do is get a helper spring. You can see it by the fan in this picture:
Since the jackshaft opener is just spinning the spring loaded shaft, it has a cable tension sensor. If the cable goes slack, it won't close the door. Since there isn't any weight pulling down on the cables when it's fully opened, you have to have a helper spring (or don't let the garage fully open) to get it started.
I originally bought 2 pairs, but discovered that having 2 on one door outpowers the "park" function of the opener and pushed the door back closed a bit after it was fully opened. A single one worked perfectly.
As a result I do have two of these that can be had providing someone either picks them up or pays shipping.
Welding screen
They don't help protect people from the light, they only stop sparks.kinda what I was thinking, but I’ve only seen that in shops where a bunch of people “not welding” are walking around. Haven’t seen one in a garage environment. Or is it more for keeping spatter from hitting the RV more than protecting people eyes from burning plasma light?
I got tired of having bits of steel melted into every window/windshield on all my rigs. With multiple rigs in the garage at once, this protects the glass when I'm grinding. It's not really necessary for welding since the sparks don't go as far.
Is that something you got from a welding supply place? We could use something like that in our shop. I always have to remind people working at the welding table to look around and make sure they're not showering a brand new sign or a vehicle with welding and/or grinding sparks.They don't help protect people from the light, they only stop sparks.
I actually ordered mine online from Akon (https://www.curtain-and-divider.com).Is that something you got from a welding supply place? We could use something like that in our shop. I always have to remind people working at the welding table to look around and make sure they're not showering a brand new sign or a vehicle with welding and/or grinding sparks.
