The new shop. Progress.
you know you could have run it in the attic and done just the drops down threw for a even cleaner install . and maybe a white plastic line to blend in better .i can see the red as a warning thing for the stupid people in the world tho . . .
but yes looks good and :waytogo::waytogo: on the drain for each drop so many people forget this and cray all the time my lines are always wet . . . no way to drain them gets this problem .
shop here in town did whole pex install years ago after a shop fire gutted the place . been holding up great in the 4 bay shop .
I did not want to crawl around a 140* attic and have to work at the rafter/joist base plate. Also, the temperature change in the lines running through the heat or cold seems to make more issues with moisture. Could not find 3/4" white. 1/2 and 1 inch yes.
My compression tool only goes to 3/4. Did not see the need to buy the 1" tool for anything in the future.
