The new shop. Progress.
Bolt through into the granite.
I will dig down to it. When I drilled the concrete, it hit air under for the length of the bit. The granite it protruding from the ground right behind the shop in line with this area. I am going to get the concrete cut and pulled tomorrow.
Sounds like fun.....
I have not been able to work on the lift. So much food truck work I am exhausted by the time the evening rolls around. And I have been out of heating fuel for 2 weeks now. So It is cold by the time it gets dark.
Found 2 sources for heating fuel. Bought a transfer pump and two 275 gallon totes. Will pick up 200 gallons Monday. He said he can supply 100 gallons a month. The second guy is about the same.:woot:
fyi just get some fuel oil and run that also . diesel fuel . kero also and mix it all up and make it last longer . if heating oil straight just tweek the settings and run it .
