The ORD Jimmy.......WEIGHT?
Greg72
@MIGHTASWELLK5
Staff member
Super Moderator
Austin, TX
Stephen,
I know it's kind of an unusual question, but have you measured the overall weight of the Jimmy with all the mods and changes to determine if its lighter or heavier than stock?
My guess is that stuff like those 42's add a LOT of extra weight....as would the 1-Ton axles......BUT......lots of other trimming and throwing out of factory sound deadening, and carpets might offset that somewhat.
Anyway, just curious if you have a "ballpark" idea, or even a very specific idea...!
You could always do a contest for the CK5ers: "Guess the closest to the Jimmy's actual weight" and win a valuable prize!!!!
-Greg72
'72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
<font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
Hmmm, a "How big is Stephen's Jimmy" contest.
Steve
Director of Global Expansion
my guess would be 5600
<font color=green>Chaz</font color=green>
<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>
LOL!!!!
Er, Uh.....well, I guess that IS what I asked.....isn't it?!!
-Greg72
I'm going to go with 6200 lbs.
99 3500 dodge cummins, blah, blah, blah
soon to have: 90-91 blazer or jimmy with 6.2
I love the smell of diesel in the morning. (no,not really;))
I'll bid 5601 lbs Bob...
J
See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
<blockquote><font class="small">In reply to:</font><hr>
<hr></blockquote>
What exactly are you referring to?
I'm not picking my nose...I'm just pointing at my brain!!
<a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
ok wes you sicko...get your mind out of the gutter...
btw my guess just changed to 5602
My guess is 6000 lbs even.
Rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
did I say 5601? I meant 5605. =)
J
5895 lbs.
See Ya,
Keith
<font color=green>Born to Drive My K5</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
It's 6600 pounds. Here is a post from pirate4x4.com that I had copied into a Word document. I don't think it's on their forum any more becuase they went to a new server? I think it was a post about what spares people carried etc. Yes, I'm a full size information junkie.
35 spl locking hub
Driveshaft, fits front or rear (only if I know I can't limp out on 2wd)
fluids to limp home
Electical parts and wire
HEI coil
Fuel pump
tire plugs.
In the 1/2T axle days I carried spare assemblies, a drive gear,caliper bolts, spindle nuts, and an outer wheel bearing. I had dropped the outer bearing in the sand once, so I carried a clean spare.
The K5 is up to 6600# now, I try to carry as little as I can get away with. Course part of the reason it's so heavy is the 1-ton drivetrain to make sure it doesn't break because it's to heavy?????
Per SW - por post.
Not only does the 1 ton running gear, doubler, and big block add weight, he has the frame rails boxed in the front to support the link suspension. Also, he has added a lot in the tube work (full cage, bumpers, rocker guards etc.) I actually looked at it when I dropped by his shop about 2 months ago. To say it is heavily modified would be an understatement. Interestingly enough, I also spotted Project UAV in the Bennigan's parking lot in Denver on my trip to Colorado and got to look at it too.
Ryan
In TTC trim it was 6600 without me in it. OINK.
Now with no soft top, doors tailgate, spare, toolbox or parts, I'm guessing about 6K even. There's not a lot left to lose. I'm looking into chopping the hard top and a redisign on the traction bars will lose a little there, as will taking the 2.5" shackle flip brackets off but beyond that we start getting to expensive weight, like 'glass body parts, alum. heads, alum wheels, etc. I'd like to get an alum. skidplate since a big sheet of 3/16" AR plate is pretty heavy, but I like the way it holds up to rocks, the AR plate doesn't scratch when you hit it. 1/8" chromoloy was my 1st choice but it's a little pricey.
I could lose a little off the lower front link arms, they're 3/8" wall thickness in the middle, but I don't think it's worth building new arms for it for a couple pounds on the bottom of the truck. Dropping tire size loses some weight, but then I don't have 42's any more and I kind of like them. when you start with a wheel and tire that weigh 135lbs each, you can bet it's going to be a heavy truck overall. The steering arms weigh 9 lbs each! there's probably 25 lbs of lubricants in the thing too between all the gearboxes, axles and motor. And 125 ft (roughly) of 2x.120wall tubing. That adds up quick!
It's getting really close to as light as it can practically be. I might be able to make 6600 with me and the gear in it, but I'm not hoping for a lot more.
To be light you need to start with light in mind and I didn't do that so now I have heavy. But it still works pretty good! And considering all that's in it 6600 may not be that bad, I've heard of similar rigs over 7K#'s.
Making the world better, one truck at a time.
SW-ORD
&lt;a target="_blank" href=http://www.offroaddesign.com&gt;www.offroaddesign.com&lt;/a&gt;
Thats not bad at all. A friend of mine had has Blazer on 44s, 1 ton and BBC with no spare parts or people in it weigh in at like 7400lbs or so.
Ken H.
'86 K5 in parts
1-ton 454 44 TSLs
hey stephen, you could always get a fiberglass hood and make yourself up some jeep-like soft doors. That'd save ya a lil weight. =) Speaking of which, anyone know where you can get a fiberglass hood for a K5 for under $500? I barely ever see them and when I do they are way spendy. Seems like a pretty simple thing to make from fiberglass...it must be a low sales quanitity that makes them so costly.
J
The only glass I've ever played with has been race skins and they've never been on my own truck. I'd probably go to Autofab or one of the similar desert shops for lighter front parts. Once again you're talking big bucks to save weight. The hood might be worth it but my fenders are getting pretty light as they are. And race fenders are kind of bulgy and I don't want any more fender width than I have. Plus they're not built for 42's.
Really I'm going to be happy pulling some weight off the top and that's about all I can do. It's weighed about the same with a couple different drivetrain setups and without starting over it's not going to get much better. It was about 6K# with 1/2T axles under it!
SW-ORD
<a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
