"3/4 full" on the guage is always closer to 1/2 a tank IME. Every square body I've owned is like that. From "overfull" when you fill it, to the 3/4 mark is close to 1/2 tank in volume.
Rene
Ditto
Rene
Before I fixed the sender wire, they were laying bare wire on the tank and they were grounded...it was pegging at the 3 o'clock position.
I shook the truck and heard the gas sloshing around, I figured that would resettle the float.
Do you think it's the sending unit?
more common than you might think... did you go with the HD version?
Keep a close eye on your waterpump....
I think I recall that a bad fan clutch can take the waterpump with it, so watch for signs of weeping coolant from the back side of the pump or any little puddles of bright green fluid on the ground when you park.
usually the clutch rears it's head at slow speed/idle stuff, highway speed temps come back to normal.... ime, the HD's are MUCH more durable....
does the gauge appear to be accurate now compared to the IR?
I found the wire that goes to the factory temp gauge in the dash. I grounded it and the gauge goes crazy spinning all over the place.
The sender wire shouldn't be grounded (at least not directly). The sender wire goes to between the sender you just installed and the sender connector on the back of the gauge. There is usually an additional ground wire that goes from the gauge to a chassis ground.
When you deliberately short out a sender wire (to ground) the needle should swing to the low side of the gauge, and if you remove the sender wire it should swing to the high side of the gauge. It sounds from your description like the gauge is functional and you might just have the wires crossed-up.
Sweet!! looks like the 4x4 post works just fine too.
Rene
