GRINCH
Keep looking on the 1st post. I will update/add/remove daily.
All prices DO NOT include shipping! But all prices are negotiable
Edelbrock Remote reservoir shocks. New at Jegs $182 each.
Medium Valving Part# 63901 Extended 23.35" Collapsed 14.45" Stroke 8.90" Remote Mount holes HS13/HS13 Zinc finish
I have 2 of these new in the box. 2 for $280
Stock front tow hooks Chev $30 (2nd Gen)
Wiper Motor Pulled from the 90 only used 2 Months $20
Dana 60 F Open Carrier $50
Corp 10 carrier $10
14SF 4:10 Ring and Pinion $50
AC compressor. (Newer model) Make a offer
700R4 to 241 adapter Will also work on a 208 to TH350 $45
Green door panels Plastic 1972 $25
Door Hinge New LH top $8
Like new front drive shaft 25 1/4 compressed 28 1/4 Extended. Was mounted on a 72 blazer 205/D44 $75
Used starter from 90 K5 $10
Corp 10 bolt rotors/hubs/calipers almost new pads $25
New shock boots. I have 4 black and 2 red. $3 each
3" Stainless Exhaust tip fits on 2 1/2" tailpipes Edelbrock 5582 New is $45 I have 2 $60 for the pair.
New unk brand shocks 17 1/2" compressed 29 1/2 extended $20 pair
2 piece fan shroud pulled from the 90 blazer $30
Lincoln Mig weldpak 100 converted to gas already with gauges. Works great. $250
Fan blade and clutch 5 Bladed pulled from 90 Blazer $10
Rear seatbelts 90 Blazer Lt Grey/Blue $25
Blazer Bucket seats from a 90 Blazer Lt Grey/Blue $75
Receiver hitch pulled from the 90 $50
Clutch pedal parts from a 72 Blazer $30
Single Hub M/M all steel $5
New coil Napa IC29 GM 90 Blazer and many others $20
New MSD Master Blaster 2 Coil Tower type. $30
32 9/16 Lug nuts tuner 6 spline style with Key New $25
Power Tank Monster Deflators New MON 8200 $90
Battery trays, Dual, Driver and Pass. Pulled from the 90 Blazer, in great shape. Both $50
K5 Blazer fender Badge 1972 $15
Blue Center console 90 Blazer (two small cracks by the hinge)$35
Interior Spare tire mount with cover 90 Blazer $25
Corp 10 carrier $10
