The project is done sale
GRINCH
Helena, MT
Keep looking on the 1st post. I will update/add/remove daily.
All prices DO NOT include shipping! But all prices are negotiable:deal:
Edelbrock Remote reservoir shocks. New at Jegs $182 each.
Medium Valving Part# 63901 Extended 23.35" Collapsed 14.45" Stroke 8.90" Remote Mount holes HS13/HS13 Zinc finish
I have 2 of these new in the box. 2 for $280
Stock front tow hooks Chev $30 (2nd Gen)
Wiper Motor Pulled from the 90 only used 2 Months $20
Dana 60 F Open Carrier $50
Corp 10 carrier $10
14SF 4:10 Ring and Pinion $50
AC compressor. (Newer model) Make a offer
700R4 to 241 adapter Will also work on a 208 to TH350 $45
Green door panels Plastic 1972 $25
Door Hinge New LH top $8
Like new front drive shaft 25 1/4 compressed 28 1/4 Extended. Was mounted on a 72 blazer 205/D44 $75
Used starter from 90 K5 $10
Corp 10 bolt rotors/hubs/calipers almost new pads $25
New shock boots. I have 4 black and 2 red. $3 each
3" Stainless Exhaust tip fits on 2 1/2" tailpipes Edelbrock 5582 New is $45 I have 2 $60 for the pair.
New unk brand shocks 17 1/2" compressed 29 1/2 extended $20 pair
2 piece fan shroud pulled from the 90 blazer $30
Lincoln Mig weldpak 100 converted to gas already with gauges. Works great. $250
Fan blade and clutch 5 Bladed pulled from 90 Blazer $10
Rear seatbelts 90 Blazer Lt Grey/Blue $25
Blazer Bucket seats from a 90 Blazer Lt Grey/Blue $75
Receiver hitch pulled from the 90 $50
Clutch pedal parts from a 72 Blazer $30
Single Hub M/M all steel $5
New coil Napa IC29 GM 90 Blazer and many others $20
New MSD Master Blaster 2 Coil Tower type. $30
32 9/16 Lug nuts tuner 6 spline style with Key New $25
Power Tank Monster Deflators New MON 8200 $90
Battery trays, Dual, Driver and Pass. Pulled from the 90 Blazer, in great shape. Both $50
K5 Blazer fender Badge 1972 $15
Blue Center console 90 Blazer (two small cracks by the hinge)$35
Interior Spare tire mount with cover 90 Blazer $25
how many zero rates? enough for both axles or just one if its enough for both axles i might want them it will be sunday night untill i can get back on i am about to head to the lake
Just one set. I do have a used tapered set that I didn't list. 5 Degree taper
Would like to see a pic of the new " new unk brand shocks 171/2" compressed 291/2" extended $20 a pair "
also price to ship both pair to 22151.
thanks
thanks
Only one pair. I will post a pic tonight. Shipping will be $19 to a home address a little cheaper to a biz address.
Any pics of these? I'm guessing they are some form of anti-theft lugnut?
They look like these. They are both anti-theft and allow the lug nuts to fit in smaller diameter holes in the rims. I need this style because the rims I choose have a small diameter lug hole. The standard lug nut was tight on the sides even using a thin wall socket.
I will take the Dual steering stabilizer. I'm in Billings so UPS ground will be cheap and get here in one day.
Sorry It's sold. I missed that on the update. Bummer.. I'm heading your way for work next week.
Have you sold the tranny lines yet? Mine are pieced together and I'm spending the summer replacing crap parts. I'm in Billings as well.
