Funny, I’m doing the same thing with a vw at the moment and thought of the same person.
I have 2 starters with good motors. One has a bad contact across the relay to the motor, the other has a stripped postFunny, I’m doing the same thing with a vw at the moment and thought of the same person.
Mine goes click but the starter tests fine…
Nice, I bypassed the ignition switch and hot wired the car… I guess transferring the switch to the new housing it broke…I have 2 starters with good motors. One has a bad contact across the relay to the motor, the other has a stripped post
Crimped solenoid, wasn't able to mix and match
However, I still had one more mini starter in my magic stash![]()
Tires spin in third
It’s a clutch car. No free hands or free time like a slush machineThat statement with no video? For shame….
It’s ok we know you dumped the clutch with that 305 to do itIt’s a clutch car. No free hands or free time like a slush machine
Wind et up and go!It’s ok we know you dumped the clutch with that 305 to do it
you mis typed 306I guess since the rumors have stopped flying
The engine in this car is the heads and intake off the 350, bolted onto a 406 with forged internals
The engine in this car is the heads and intake off the 305, bolted onto a 406 with forged internals
So what block?I guess since the rumors have stopped flying
I want to see the balancer than can spin a block to balance it.So what block?
Is it internally balanced? (Not that it matters much.)
Not sure why that would be needed.
Good trySeems like 350 heads might be better for this application, no?
