The Purple Camaro
Pulled the radiator cap off the other day and got a load of brown oily schmutz floating on the top
Now before we freak out, I didn’t reuse the head gaskets, but I did reuse the antifreeze.
I had just changed the plugs so I didn’t suspect anything rotten in the cylinders
So even though I only had half the miles on it for break in, I went ahead and pulled the oil and filter for a check
Not only was the oil clean, I didn’t have to use a hammer to pull off the filter.
Parameter controller
Works great to force it into a gear so I can make it cycle through and RPM range without trying to shift
then it will analyze whatever data log you load into it, or as many as you load into it at once:
WBO2
Can you display counts per cell in the VE table screen? Per our text and those pics I sent it can help show data you want to eliminate.
It won't blend the two, or at least I haven't figured out how to yet.
But more time and data points allow it to do what it needs. Until then I can flip back and forth and see
Always more time and more data. Steady state driving is key. Per our convo we have to hope they have the data filtered good.
Added a bunch more 2 and 3% based solely off the MAF. I need to disable the MAF and let it log to correct back onto the VE table now
