The Purple Camaro
map 5029
406"
35 lb
58 psi
Running pressure 56psi at the highest
idle cruise runs about 51psi
on these MAPs 1psi = ~1% on fuel trim
So new settings
idle/cruise/accel
13.7/14/12.7
22 idle timing - 34 total by 3200 +10 vac adv
Fuel modifiers
idle -18
cruise -16
accel +12
pump 53%/30%
Still some lean on tip in, but it is adding fuel itself under tip in conditions, some times into the mid 20%
First time I've had it consistently add fuel under accel
into single digits at idle and cruise
