The Purple Camaro
map 5029
406"
35 lb
58 psi
Running pressure 56psi at the highest
idle cruise runs about 51psi
on these MAPs 1psi = ~1% on fuel trim
So new settings
idle/cruise/accel
13.7/14/12.7
22 idle timing - 34 total by 3200 +10 vac adv
Fuel modifiers
idle -18
cruise -16
accel +12
pump 53%/30%
Still some lean on tip in, but it is adding fuel itself under tip in conditions, some times into the mid 20%
First time I've had it consistently add fuel under accel
into single digits at idle and cruise
Well, we did one car, and then we did the other. So technically we both hit 120 miles an hour at the same time two different times.
zl1 pulls really smooth, stick your back in the seat for a couple gears worth. You can hear the supercharger kick on once it starts getting away from the torque management settings in first gear
Yes, but I don’t recall “that” compressor kicking on much when his foot was on the floor
They shut off when you go WOT. My 16ss does as well as did my scat pack. I always forget and then get nervous I blew something up when the vents start blowing warm air.
Yep, they put that in the programming a long way back. Even my 94 is set up that way think it kicks out at like 85% throttle.
The drag car is definately faster, but I still had fun. :P
I know what happens to those AC pumps at the rev limiter. Pop. I have to remember to turn the AC off.
Nah. When it blew the shock mount off the spring plate, I must’ve moved it just a touch. Drivers side pushes the car some, has too much pre-load in it now
