The Purple Camaro
Where the term big n little tires came from or Pizza cutters.
It screams drag car when you see them. Something about a first gen Camaro with pizza cutters up front and 12” wide Mickey Thompson tires out back. It just looks “right”. Like they intended them to be that way.
Here we go!!!
is that the accumulator in the trans parts box?
did you inquire about the corvette servo upgrade?
Here we go!!!
I would bet that it has the corvette servo already, just based on the fact of his recount of the work done. Heck, one of mine got that upgrade back in 1997. Only pulling the cover will tell, of course.
Car has turned into the old dosie doh!. One step forward, two steps back
Had to drill the spring plates to add the shock stud to do the shocks right
The tail shaft is held to the mount with one bolt. I need to drop the crossmember to slot everything to get both bolts in, and the governor can only come out when the cross member is out
