The Purple Camaro
map 5029
406"
35 lb
58 psi
Running pressure 56psi at the highest
idle cruise runs about 51psi
on these MAPs 1psi = ~1% on fuel trim
So new settings
idle/cruise/accel
13.7/14/12.7
22 idle timing - 34 total by 3200 +10 vac adv
Fuel modifiers
idle -18
cruise -16
accel +12
pump 53%/30%
Still some lean on tip in, but it is adding fuel itself under tip in conditions, some times into the mid 20%
First time I've had it consistently add fuel under accel
into single digits at idle and cruise
Circling back on this as I never really got this update
Replacing the MAP was just the start. From there I dumped the learned data and started over
With the not so helpful help on the Edelbrock forum, I ignored what they were telling me and just started writing things down after each drive and working out some of the hard settings and then doing a full relearn
After a handful of times doing that and getting the global and AFR numbers really close on the first learn, I dumped everything again and then set the initial learn speed at SLOW for the first drive after clear, watching the velcro phone. I made 2-3 drives, one on slow, then one on fast, and another at slow before turning off the self learn settings
This allowed me to watch when the ECU started cutting fuel below 2000 rpm. What it's doing is picking up the overlap in the exhaust and trying to make it go away.
This was making the transition area on the map too lean on tip in and it wasn't able to catch up fast enough on tip in to compensate, thus a lean miss
If you rolled into it smooth or nailed the throttle, it would mostly be ok
Using different fuel maps was actually worse
On these drives I had 0/0 on the accel shot settings, then adding more in after the learn was off
This added back in whatever the ECU had trimmed out making it too lean.
I will still mess with this accel setting, but this is the beast the transition has been since I put the 406 in
the 350 had a 221/229 112 CL cam, where as the 406 is 231/236 110 CL (both at .050")
