You'll need an aftermarket pitman arm, something that allows you to run a drag link style tapered end. Then just some tubing and a couple threaded inserts.
Basically like this stuff that I just took out of my K5.
When you get the 60 in. Lemme know. I need a xover in the Jimmy
With how it is now you wouldnt be doing anything twice, if you are doing crossover on the 60 its just replace a cap with a steering arm and bolt the draglink back down.
All you have to do with the 10 bolt is swap the box, or sector shaft, new pitman arm and run a draglink.
I felt like my steering wheel smoothed out on the road with cross over. The roads in oregon where i used to live would pull the wheel hard when you hit a big bump in the road with push and pull style steering.
Will do. Will be next year sometime. Hopefully sooner rather than later. I have half a mind to make it to BB19 ...
Better make it a whole mind!!!!!! That's a long trip.
I was gonna mention when I was towing with my 6.2 220 is about as hot as it got. I ran it there for about 20 miles foot to the floor going 25 mph.
Serpentine belt swap with the newer 6.5 water pump and the fan should help. That's the plan for my Jimmy but I'd imagine you already knew that
I am also running a dodge 60, and I ran a 10bolt/D44 before that. The dodge is actually narrower, so when it comes time to swap, you cut one end off and weld in a new threaded insert. Super easy.So I would be using the same drag link on the 60 as I would be on the 10 bolt. Does the fact that my 60 is a dodge make any difference? Perhaps in length of the draglink?
The RPM calculator says I’ll be at 2183 rpms at 70mph which seems like a pretty good spot.
The engine is fine at 2200RPM. You can cruise well at 1800RPM with that engine, and I run mine slower than that. So 2200 in O/D is overdoing it a little bit for road use. But you're not going to hurt anything aside from mileage and perhaps your ears (depending on your exhaust).
I think David's running 4.56 gears with 40s. But don't quote me on that.
He’s got 4.88s with the 40s and has commented on how much happier the engine is with the 40s vs the 38s.
Calculator says I would be at 2040 with 4.56 and 1834 with 4.10 which is what I have now, when I move to 37s. Calc gives my 33s and 4.10s 2,015 rpm so almost seems like if I stay with 4.10s and go to 37s, I will have the same net effect as David’s 38s to 40s with 4.88s.
If I remember correctly, the engine seemed pretty happy with my worn out military 37s. I remember being relatively impressed with the truck's ability to move down the road on the trip home after purchase.
So perhaps the best thing to do is stick with the 4.10s. I guess I was thinking since I have to regear the 60 anyways, now might be the best time to gear to 4.56 or 4.88. But I suppose it makes more sense to build for what I actually do, instead of what I might do. I guess if I ever do find that I need a lower gear ratio, they aren’t that expensive so it won’t hurt to do it again.
Easier yet...change tires before you regear the D60 and see how you like it. If not happy, pick a ratio then, after you better know exactly what you want.
