The Ruffstuff 14Bolt Complete Swap Kit!
Gravel Maker
Sacramento, CA
This is everything you need to swap in a 14 Bolt Rear Axle into a leaf sprung rig with all the options! The kit includes the Spring Perches, Ubolts, Ubolt Plates, Shock Brackets, Disk Brake Brackets, Pinion Guard, & then we top it off with a 3/8" thick Diff Cover.
Most of the 14 bolt guys have used 1 or 2 of these but on your next build get'em all at the same time and save even more! $325 Before the CK510 discount!
thanks for the speedy delivery dan!! i received my kit monday afternoon, nice stuff!!
but my question is the holles in the plate and spring pad they are even....i thought one hole was 1 inch and the other would be 1 and a half inch offset for moving the axle if needed?? could you get back to me about that? thanks mark
