The shakes!
JJ85K5
So Cal
i just put in a dana 60 and now the blazer will not stop shaking. as soon as i hit about five miles per hour it shakes from side to side, bad. it doesn't do it every time, it's about 80% of the time. the thing is, it didn't do it when i had the corporate 10 bolt in there. the only thing i did was put in the dana 60, same suspension, same same sway bar, same everthing. waht's up?
Do a search for death wobble or DW & you should find enough info to read for days.
