The Shop Truck
1971 Chevy C20 with a custom flat bed.
So I can't find any minimum delay setting in the software either. I measured my shifts and it was .58 seconds from the call to shift and .37 seconds to actually make the shift once it starts. However, if you look at the actual gear ratios it takes .18 seconds to from when the ratio starts to change to when it is full changed ratios.
Here is an NA pass with my regal. Except you can see the launch caused my foot to let off the throttle a tad, I learned quick to correct that one.
I may make a youtube video showing people how to do this.
The blue line is the "gear ratio" math channel that calculates the trans ratio. With my trans brake it lets the input shaft turn some on the brake which means the ratio is infinite with the output speed locked, but you can see the ratio come in and then you can see the gear changes happen pretty fast, and if you hover on them you can see them go from 2.48 to 1.48 then to 1. This line will be off in 4th gear as the OD planetary is in front of the turbine shaft, but I don't use 4th at the strip anyway except sometimes at the shutdown area.
The peach colored line is the converter slip math channel. You can see it peaks during the transbrake, then it peaks again during the gear changes and it drops to its lowest point at max RPM right before the gear change.
The rest of the lines are standard Holley channels with a 4L80E. RPM, TPS, gear, input shaft speed, speed, line(trans) temp.
You can also see the TC Clutch output I created so I can lock it immediately whenever I want, on a timer, at a certain speed, etc. I use speed.
Here is a nitrous pass where I lock the converter....it looks like a 4th gear but its not as you can see.
Here are those two math channels. I may make a youtube video on how to do this...
The converter slip is easy, just
((RPM/Input Shaft Speed)*100)-100
The Gear Ratio channel depends on what you have your stuff set at in the Holley software such as Tire diameter and axle gear, it has to match or it will be wrong.
This is the equation I derived...
(Input Shaft Speed x 3.14159 x TireOD)/(Speed x Axle Gear x 1056)
Once you do that you can see if the gear ratio is a quick change like mine on the 1-2 and 2-3, or if its drawn out or not a flat line. I have zero filtering on those lines. If the 1-2 and 2-3 looks crisp. Then look at the converter, IMO it should get to 10% or less at high RPM, mine drops down to under 3% before the 1-2 gear change and about 6% before the 2-3 gear change. You can also see my converter lockup at 135 MPH wasn't holding the full power on that run or it should go to zero slip, even though it was still dropping the slip quite a bit in high gear. The slip is less in lower gears because the converter basically has more leverage so it's easier for it in lower gears.
Hope this helps you diagnose...
Thanks @folkenheath, I'll try to set that up, it looks like useful information.
I have sent my datalogs and tunes to GearStar and they're looking at it. Their initial response is to just work around the long shifts by moving the WOT RPM shift points out of the way like you mentioned. I gave them 3 sets of datalogs, one from my last 1/4 mile pass at Firebird where everything worked properly, one with the 1-2-3 shift, and one with the 1-2-3-2-3 shift.
They talked to Yank and if anything they think my torque converter is too tight, not too loose. The tech I talked to was digging into it more and I'm still waiting to hear back from him.
I'm thinking the softer launches could be from me holding the brake harder and not letting off quickly enough. I'll be honest, when I launch it I don't even think about my brake foot, I just let go of the button and it goes. The reason I don't trigger the nitrous and 2 step with the brake pedal is because it takes .3-.4 seconds for the light to go off after I let off the pedal. When I compared my best launch (1.42 60') with my last launch that should have been quicker with the 3200 RPM leave the brake light was on for an extra .03 seconds, so that could have been the issue. I will likely be adding a trans brake to fix this issue.
For what you are dealing with I consider it vital information. It will tell you definitively if your clutches are slipping or your converter is not holding at high RPM.
The great thing about the Dominator is it records everything, so you can go back and add those math channels and then insert them into your trans graph in the data log config and see everything from those passes.
It may be the shift is slow but the clutches are holding good once complete, that can be fixed in the valve body without removing the trans either by eliminating accumulators or enlarging the orifices. I have zero accumulators. Or maybe your trans is fine, you'll know.
I also log trans pressure too, I use a 500 psi sensor in the case. So I can see that too but I hid it because the graph was busy enough for this illustration.
If you continue to launch from the foot brake I would log brake pressure with a sensor, that will tell you. The brake switch shuts off only when the brake pedal is all the way back, whether there is pressure on it or not.
I am a dealer for ATD, "Hipsters Brake". Their billet 4L80 brake is full manual and would require a race shifter and shift solenoid.
I used a brake from Jakes Performance that still allows automatic shifting with the ECU, I built the trans myself over 15 years ago before the Hipsters brake existed, I really should give it a refresh.
Gearstar actually got back to me right after I posted. Their only comment was that when it shifted right the trans line temp was 170 and when it didn't shift right it was 130-140. The difference between AZ and Michigan :).
It doesn't seem like they're seeing anything to be concerned with. There isn't a test and tune session until the 19th, so I have plenty of time to prepare. I'll likely move the RPM based shifts out of the way and use MPH/TPS based shifting like you suggested. But before I do that I need to get a new driveshaft. It shook last time I was at Firebird and I'll be going even faster now with full boost and nitrous. It shook enough that it contacted my crossmember (1/2" clearance), but it didn't damage the driveshaft so I just assumed it would be OK doing the 1/8th mile stuff.
The next event I'm scheduled for is the Kingman Street drags on Route 66, but I think we're going to bail on that one. We are going to Duct Tape Drags the following weekend though. I'll probably only make a few passes, but I'm planning on entering the burnout competition for that one, so I definitely need the driveshaft sorted before then.
I just got off the phone with GearStar again, they mentioned that I should have a pressure sensor as well, I told them about your advanced tables and they were intrigued. He's going to try to do some math manually to see trans slip.
Apparently it does lower trans pressure based on line temps, but at 130 it was only reducing it by 1% so he didn't think that would have caused the issue we were seeing. It's not converter slip, so either everything is working fine, or the clutches are slipping. When I pull the pan to do the trans brake, I'll be able to see if there's a ton of clutch material. They recommended the Rossler kit.
Hope to see you at Firebird for the Duct Tape Drags! Following along, really interested in these logs you have and trying to soak in the info.
It should shift fine at 130 or 170, or even 100 or 220.
You could of had my math channels in your data log already and not be waiting for his math. ;) PM me your global file and data log, and data log config file if you modified it, I'll put it in for you and send it back, it will take me like 2 minutes. Besides, he isn't going to do the math for every data point like the data log math channel will. You need to know it's working the whole run not just one or two data points.
Most TH400 or 4L80E trans brakes require drilling a bleed hole in the direct drum and different springs. Did gearstar already do that to prep for a transbrake? If not it likely needs to be done depending on the brake. That's not a valve body only thing. Trans has to come out and the pump, OD planets, forward hub and direct drum need to be removed, back to the center support basically. Hopefully that's already done.
He looked at it more and said the same thing.
I didn't think you could retroactively add it to an existing datalog. I had planned on adding that before the next trip down the strip, but if you are willing to do it for me DM me your e-mail address so I can send it to you.
I'm good with any of that, but they stated that the Rossler unit they recommended didn't require any additional modifications. They have 2 on the shelf, if I can't get one direct from Rossler they are going to send me one of theirs so I can get it installed before the 19th.
Also, I sent them some pictures of the truck and they want to use it on their social media, so that's cool. Maybe I can get a sponsorship, lol.
Yeah you don't have to wait for the next trip down the strip, the Dominator records everything every log, and you can add math to old logs. I sent a PM.
Nice!
A lot of this stuff is over my head, but I'm enjoying learning by watching. :popcorn:
That is why I'm trying to keep this conversation here on my thread rather than hiding it in a DM with Heath or whoever. It's hard to find this info, so I'm trying to keep this public. I make mistakes and learn from them and post them here, if everyone else did that, I could learn from their mistakes :D.
Heath, I forgot to mention that I have a full Reid case and bellhousing, so it likely has all the modifications done to it straight from the factory.
Here are some pictures I forgot to upload. If there are any repeats, sorry.
This is the adapter plate that rattled loose, I had to remove the throttle body to tighten it.
Proof that Amber can see over the steering wheel.
A random street sign I took a picture of for no reason @76zimmer
A cool checkpoint picture
We were one of the first ones at Ubly.
I actually had someone ask me how I got the toolbox into the bed. When I told him he just kind of dropped his head and walked away saying "I've been staring at that thing all week, I don't know why I didn't think about that."
The truck is even dirtier now since it didn't get the monsoon wash it had on the way to Michigan.
This is after I did a quick Dawn wash, I hope I can get the oil out of the paint.
The modifications I am speaking about are all internal to the direct drum, not part of the case. If they said there are no modifications needed they probably already did it, it doesn't hurt to do it to a non transbrake trans. But I am jealous of your Reid case!
Here is a screen shot of your datalog with the gear ratio math added.
I am sending you the log config file back, if you open that config file it will have the channel math in there when you select the "transmission tuning" graph. You can now open all your other data logs and as long as you have that config opened it should show the gear ratio and converter slip math channels there.
Keep in mind if you change gear ratio or tire size, you need to update it there too or that will math will be wrong.
I didn't look at anything else in the log or file.
You should look at your other logs now that you have the gear ratio math, I am a little concerned your second gear is going out.
Because the ECU calls for 2nd gear at 18.06 seconds, and nearly .8 seconds later, nothing happens, then eventually it hits the 3rd gear WOT shift RPM and command shifts to 3rd when only 4 seconds later finally something happens, ~1.2 seconds after it called for 2nd gear.
Then a little bit later, when you are still below the 3-2 downshift line even at 100% throttle on the chart, it downshifts back to 2nd, then it upshifts again because of the 3rd gear WOT shift, which the computer did what the charts told it to.
Then 43 seconds into the log, when you are probably on the return road, it downshifts to 2nd gear at only 15% throttle, it slips again, and then slips again at 57 seconds. Now it might be possible there is no engine braking if you are in 3rd gear shifter but in 2nd gear trans, but then why would it go to exactly 1.48 gear ratio in between there, perhaps that throttle blip, just thinking out loud there that particular part may be nothing as I don't log the return road.
I would look at some of the other logs. I would also go drive the truck in manual second gear and take a data log and get on it for a very short moment and see if it holds or slips. The data log will tell you now and without the sudden shift to 3rd you will know for sure.
I did hold second gear for about .4 seconds at WOT when it downshifted but that's not long and it was on a downshift under acceleration.
I also send a modified shift chart back.
This keeps the actual shifts below the WOT shifts, it will not shift to 4th above 60% throttle by WOT or speed. Keep in mind you can raise the WOT shift way out of the way like we spoke of, but if your second gear is out then it will just hit the rev limiter and the run will be cut short. Whereas with the WOT shift slightly above the speed shift at 100%, it will do what it did and shift to 3rd and the run is kind of saved a little bit.
The converter is slipping a little more than I would expect but considering it shifted to 3rd at such low speed that's not surprising.
I think I am going to see if I can use some sort of screen capture software to make a video on how to add that for people on my Volcano Manifolds youtube channel.
I'm just on a rollercoaster here. At first I thought I lost second, then I thought it was just tuning, now I'm back to losing second.
I guess I'll be doing some datalogging today. It's still got the party pulley on so as long as I have traction.
The transmission did feel funny on the return, and it was making a funny noise. It did that on the last two runs down the track where it did the 1-2-3-2-3 shift.
Thanks again for taking so much interest in my problems and project here @folkenheath.. I don't really know what I'm doing, so having someone with your experience helping out is incredible!
As for the datalog, I just have a button on my center console that I press and it takes a 30 second log. I got tired of having a WOT trigger because I would have to sift through 300 logs every time I tried to download one. This way I can hit a log any time I want to figure out what the Dominator or engine is doing without having to break out a laptop and try to recreate the issue.
The dominator has soooooooooo many inputs and outputs, it has so much data capture ability over the terminator on top of the internal datalogging. I'm sure Heath could get you a price on a dominator :thinking:.
I just looked up the cost of one, I don't think I need it right now or ever.
No problem you have an interesting project and it didn't take me long at all.
I lost second gear once with the TH400 in the truck, rolled the sprag, it was a 34 element sprag but the direct drum I sourced from a reputable shop was almost .002 out of round, replaced that and it never happened again.
The 4L80E has the same sprag assembly on the direct drum so I upgraded the regal unit to a 36 element super drum.
Not sure what gearstar used, but my point is it's possible for 2nd gear to be out with normal clutch wear, although its probably not the sprag for you, becuse it did hold second gear for a almost half second when it downshifted.
If its the sprag it basically has no second, it skips it.
Yeah I log 30 seconds too, one trip of zooming in on 60 second logs was enough. I trigger the log everytime I engage the transbrake but when not in race mode the same TB button also honks the horn, so honking the horn causes a data log, which is fine. I ran the TB button in parallel with the horn button so I didn't have wires hanging around the column, but I can't use the actual horn button, not consistent reaction time.
The only time that makes me laugh is when I am at the track if I forget to put it in race mode I honk at the staging beams once....:haha:
I wish the terminator had that option, now I wonder what the ecu cost is for one...
Yeah it's about double the Terminator X Max.
