We changed quite a bit while we had the transmission out. I had been having an issue where the drivers bank was always running about 1 number leaner than the passenger side, along with #6 going cold at WOT. We took our injectors and got them cleaned and tested, then I remade the supply lines for the fuel rails. Previously they came in from the passenger side and the drivers side rail had a longer line as well as an extra bend. We made a new line that goes to the middle of the truck and splits off to both rails with identical lines, unfortunately it was in the way of the transmission .
We redid the lines today, but I was short one olive ferrule for one fitting, so no starting it today. We also still need to get the sensor block mounted and run the line from the transmission to it so we don't blow fluid everywhere. The new fittings should be here before we get up tomorrow, so we're hoping to have it running tomorrow morning at some point.
I forgot to mention that we were actually registered for the Kingman Route 66 drags Friday and Saturday. It turns out it doesn't matter that we couldn't go, it got rained out anyways.
