The Shop Truck
I know a dude that wanted to get a 55 gallon drum lid off. It had gasoline in it before that.
He filled it with dish soap and water.
Let it sit for a few days.
Knocked it over to drain, all of it.
Then blew himself about 80' away from there the second he burned through.
Ended up across the street from his place. Month in the hospital.
Be very careful.
Please be careful, I'd wash it with dish soap and hot water several times and then purge with argon while you weld.
It's currently sitting outside, I had the leaf blower going through it for 3 hours or so. It's open everywhere it can be, there will not be any fumes left in it when I finally get around to welding on it. I understand how explosions work in this situation, there will not be any fumes left in it by the time I weld on it. It will get more time with a leaf blower today, plus I need to clean the outside anyways so I can slosh some soapy water through there. I would bet money that even now you couldn't spark off anything in the tank though.
I'm still alive, but I haven't actually worked on the tank y et :D. It did get the leaf blower for 4 more hours at least today after I cleaned it up.
I finished up the pump flange and got it welded to some 1/8" that's the same as what I made the tank with. I'm pretty happy with how it came out.
Tomorrow I'll cut the tank open and clean it up so I can weld this on. I should have all the parts I need tomorrow, so the truck should be running by Wednesday.
You just need to get all the fuel to evaporate and blow out so there's nothing left. Blowing anything through the tank will accomplish this, hot exhaust would work particularly well.
