School is in session!
[FONT="]So, after all of this; does it work?? I would have to say that it was worth it. We pulled a bunch of hills this summer in the mild temperatures that make an Arizona summer so wonderful. I pulled a long hill just outside of town at over 70mph on a 115* day. Prior to the new turbo it probably would have been 60ish and watching the pyrometer like a hawk adjusting throttle input to keep max EGT under the Cummins maximum allowed number. On various subsequent trips I have found that I am able to cruise up 7-10% grades much faster than I would have been able to before. [/FONT]
Interesting stuff!
good info, thanks!![]()
No gratuitous truck pictures?![]()
Nice work (as always).![]()
pretty cool Nick, good info to know and like the way you document your experiement results.
Mine has the HX35W on it now, so I'm hoping I won't have any EGT issues to watch, but I am putting in an EGT gauge just as well!
So just what EGTs were you running? And what are they now with the new turbo?
What fuel mods are done to it now?
Nice work Nick! The rig is looking better than ever but now I know why the gas sucking big block 8100 pulled way ahead of you on the steep grades in 2012 when we slabbed it from The Hole in The Rock trail in UT rolling into the high country in CO
It was that dern little turbo all along. I thought you were just lagging behind taking pictures![]()
.That's preturbo EGTs right? Your plenty good. You can sustain 1250* for periods of time. You have a charge air cooler in it right? I can't remember now.
Low boost fueling adjustment won't affect overall fueling at all. Just harder fueling under the curve. It's easy on your VE. The set screw in the aneroid diaphragm back it off a couple turns loosens spring tension on the AFC gets your fuel a little quicker.
Why I'm asking is because a near stock engine shouldn't even be dreaming of EGT issues. Should be able to stand on the throttle and hold the thing at full load rated speed all day long and not even thing about looking at the EGTs
What he said. 1150* is not a problem. Over 1300 sustained is when you should start to worry.That's preturbo EGTs right? Your plenty good. You can sustain 1250* for periods of time. You have a charge air cooler in it right? I can't remember now.
That's what I thought, but it sure doesn't seem to be the case with this one. The new turbo helped a bunch though. Maybe a PO of the motor did something very covertly?? The pump appears to be original and I broke most of the screws loose for the first time since I've had it.
You would never know if the fuel pin had been turned unless you took it apart and looked at it. Fuel pin is eccentric turning it to the skinny side forward is same as pushing Ppump plate forward.
For sure simplicity for the win.
That's perplexing still.
Pressurized your intake for leaks? Isolated the CAC?
