After hours of reading, thinking, sitting in the seat seeing where my hand would reach or interfere with crap I finally came up with my design for the switch panel.
top row
space 1- switch with red labeled cover for winch as " PLAN B" with red led light with brker
space 2- winch switch, labeled IN and out and WINCH up top
space 3-ignition switch with green labeled cover, with green led light with breaker on bottom
space 4-start button, with yellow "CHECK ENGINE" light led above, with breaker n bottom
space 5-ENGINE FAN labeled switch, with green led with breaker on bottom
space 6-TRANS FAN labeled switch with green led with breaker on bottom
space 7-CB labeled switch with blue led with breaker on bottom
space 8-TUNES labeled switch with blue led with breaker on bottom
space 9-OBA labeled switch with blue led with breaker on bottom
space 10-GPS labeled switch with blue led with breaker on bottom
bottom row
space 11-DOME LIGHTS labeled switch with yellow led with breaker on bottom
space 12-HEAD LIGHTS labeled switch with yellow led with breaker on bottom
space 13-SPOT LIGHTS labeled switch with yellow led with breaker on bottom
space 14-FLOOD LIGHTS labeled switch with yellow led with breaker on bottom
space 15-ROCK LIGHTS labeled switch with yellow led with breaker on bottom
space 16-REAR LIGHTS labeled switch with yellow led with breaker on bottom
space 17-RACE LIGHTS labeled switch with yellow led with breaker on bottom
space 18-AUX labeled switch with yellow led with breaker on bottom
stager two 12 volt cigarette lighter plugs with covers on opposite ends in the center of the panel.
separator tube handle thingys on both ends of the top row, and dividing switched 2 and 3, and 6 and 7 .
Along the top of the panel ORGAN DONOR RACING
Its a weeeee bit crazy and in depth but awesome at the same time.
Any thoughts or input is welcome or feel free to toss out ideas on what you would change, ditch or add. Damn 4 am and I slipped up on the spelling of donor .. doh!
There are led indicators above where needed and 20 amp resettable breakers below each switch 21 amp. Wiring to be 16 gauge.
Going to have 12voltguy.com make it or
www.oceanstatelaser.com
