supersize75k5
OrganDonorRacing.com
So been super busy but should have updates soon
the 07 I had a trans built just as a stock rebuild and going to take mine out to finally get built. I usually get slow in december so should be able to get it installed pretty soon. Also on the hunt for a 08 style single cab to convert over to at some point.
the buggy, being that I am busy I decided to drop the 14 bolt front axle back to Andrew at letzroll offroad. Going to have him do the ballistic cover and shave kit for me, 2.5 psc double ended Ram, new artec keyed arms and matching keyed solid axle industries knuckles are ordered too.
Also having him make a me a couple more links, the ones off the last buggy had left and right thread and I really want to just switch over every thing to right hand tap for simplicity of spares. If any of you ever need links, Andrew has the hook up!
Now off to the real fun
Also making up my mind on the next project, ive been wanting to build a brute to replace the 06 ext cab truck. Well the final plan is to turn a tj into a scrambler instead
But maybe using the drivetrain and axles from the 06 rather than selling it...
Would move the axle back a bit to solve some of the overhang and use everything and all the wiring from the chevy, with some 37's to keep is reasonable. Wheel base would end up around 106" from the 93 that a tj is.
m excited about it because it will be different, actually fit places and I should reasonably be able to beat on it with armor and tube fenders from front to back
here is pics of the heep canvas, and yes I know I need help.
Would move the axle back a bit to solve some of the overhang and use everything and all the wiring from the chevy, with some 37's to keep is reasonable. Wheel base would end up around 106" from the 93 that a tj is.m excited about it because it will be different, actually fit places and I should reasonably be able to beat on it with armor and tube fenders from front to back
Being I seem to kill a lot of auto trans I am building this with easy removal involved.
