Thanks man. From the initial design to this point, there are probably 30-40 hours into these two firewalls, but I’m also learning as I go.Dude, that's nicer than factory stamped sheet.
David
Didnt seem that hard to meMawwiage.
This was a B to fit up and keep square. I’ll double check in the morning before I weld.
David
I hope those ideas are what we heard about awhile back.
Probably just a cam and peripherals. 650ish hp is more than enough to evaporate 325s.I hope those ideas are what we heard about awhile back.
What is the fix? I'll look it up but being lazy right now.Please read up on LS7 head issues, valve guides and valve springs. Fix those, ask me or my brother how I know
Might as well put a bigger better head on it at that point to be safe and sell them to a vette guy.I've read that some valve guides are incorrect tolerance from the factory, some the valve job is not centered on the guide, and some wear too fast, but may be related. Some sources say its limited to certain dates and manufacturers, but it doesn't seem clear.
I think roller tip rockers would help with wear, but they won't fix it if its a material issue.
I think the valve springs will be swapped with the cam anyway.
The guides can be checked with not too much extra time. If something is wrong, it would need a valve job, or new guides, or both.
