beags86
Eastbound and Down
Table level up - second iteration:
The garage floor has a 1/8"/ft slope to it, and the forward adjusters were close to maxed out, so I pulled the jam nuts on the rear adjusters to get the table 1/4" lower overall.
The relevel yielded better results than the initial - 0* variance side to side. Front to back is a little different - 0.1* on one table rail and 0* on the other, though my bubble level(s) looked smack dab in the middle of their lines. My nice 4' level is on permanent loan to my dad, so I'm going to get a new one and double check the measurements before locking anything down.
Car level up - first iteration:
The car does need some assistance getting level side to side. The front is off by 1/8" rail-to-rail while the rear looked more like 3/16". The rockers leveled out perfectly from the start (measured from the top pinch). I'm experimenting using inverted and normal quick grips and shims, moving around the car to the (presumably) level table beneath it to get uniform readings.
I left the shop with all bubbles sitting within their lines and gauges reading 0* or 0.1*. Doing the math, 0.1* over 15' 9" amounts to less than 1/32", which is acceptable given that the unibody probably wasn't flat when it left the St Louis production line. Parallel and perpendicular are more important as the reinforcements are integrated.
David
Your proably 1000 times better then that factory dodge body is... Mopars were pretty notorious for there poor quality body's in the 60s and 70s.... Not that a mopar guy would ever admit that...
