The Wonton
Yep, it sounds like the comp kit should work just fine for what I need @folkenheath
The comp kit is nearly .100 longer, you are good with that? Can you look at some cylinders that are not bent and look at the rocker travel range? Just imagine the pushrod tip being .100 higher along with the nut and the pivot being in between there.
We could get you the same lengths you have with Howards. Or if you look at the geometry we can skew it a little longer or a little shorter depending on how it looks with what you have. Just let me know and I can get send an invoice and get some on the way.
That was a bitch and it's hot out here, lol. Jon, you get what you get... Hopefully Heath says that looks good, lol.
