supersize75k5
OrganDonorRacing.com
my mind just started thinking again..I might have a use for these or something really close to it...
we should call curt the new bueller..
Winner!More specifically, adjustable 1 ton style forward hangers for rear springs.
warmer?![]()
Is there a way for something like this to be used when swapping in a 14bff so you dont have to move perches too?
Winner!
To fit my '74 Blazer chassis and a D70HD rear without cutting and relocating the spring perches.
Yes, it would. But I'm not like you.Wouldn't it be way cheaper to just move the perches?
Not sure what size the bolts are as I haven't gotten that far yet. I sent these brackets back to Kert and he's using them for his build up project of the short bed truck. He redid some brackets for me of which I still have here at home but they're not quite right so again, he's making another set. I will be sending this current pair back to him and maybe someone else can use them?what size are the bolts your going to be using to hold them to the frame? btw wes, did you get your standard cab 1 ton dually?
