Moody
admitting you have a problem! Although not on the scale of Greg, I definitely have the "might as well....." problem! Let me explain....when I bought my truck five years ago, it was going to be a stock restoration with MAYBE 33's and a two inch lift. Here I am five years later with 6" and 7" inches of lift, 35's, SM465 swap and 4.10's and it's STILL not enough. Now I'm looking at 4.56's, 36's or 37's and heaven forbid....trimming sheetmetal
Kert is working on some custom beadlocks and I have some new LTB's on order. Worst of all is I haven't even driven the truck yet! I don't have a problem trimming the front as those are easy to replace. The rear quarters however, I am a bit hesitant to cut those as goods ones are hard to find. What do you guys think? Should I cut the fronts and leave the rear alone or do you think I can trim the rear without ruining that classic look? I'm standing on a deep cliff guys......
I just assumed that so many people are using them on the H2 rims they would just snap right on......wrong! After spending about an hour scratching my head and getting downright PO'd I realized you need to take about 1/2 to 3/4 of an inch off the backside to allow them to fit in the hub area and for the plastic lugs to screw on. One word of advice....if you use a grinder to grind down the edge make sure you have a good respirator, they put off some nasty fumes! If I had to do it again I'd use a cutoff wheel.
C'mon everybodys doing it. You know you want to. You won't know how it feels until you try!!
