beags86
Eastbound and Down
Sounds like you found your problem.
There isn't one - it's drive by wire.May want to check your idle air valve for the surging/idle issues.
A/C was working and sweating the lines. I did notice a strange sound during the test drive which I've since attributed to belt slip. The tensioner for the A/C belt (A/C has it's own tiny serpentine belt) developed some strange friction where it doesn't always apply tension, but sticks in place. Also, the tensioner pulley bearing doesn't feel scratchy by hand, but is loose enough to move rock side to side a bit. I have a new tensioner, pulley and belt on the way. I've been moving the trailer around the yard with this rig recently and it has been running fine (no tensioner or A/C belt installed).Worth wondering but was the AC working (blowing cold) before you disconnected everything? Maybe its the compressor? They can make a lot of noise when the inside gets plowed..
