Fred_M1010
Damn, this thread seems to be one of those deleted in the database crash
There were some replys that I didn't have the time to read before they vanished, so if you could re-post them it would be great
I think I recall my last question was about how a fixed yoke from a pinion would fit the output axle on the 241...?
I would cut the axle down in length and either make a threaded hole in the end of it for a bolt, or turn an "outside threaded part" and use a regular pinion nut.
The 241 output axle is 32-spline and 35mm (~1 3/8") in diameter all the way.
But I suspect pinions are slightly tapered...?
And second question is about hardening the material...
Does the axle need to be re-hardened afterwards?
