y5mgisi
1 ton status
Not that it means anything but i have re-adjusted the valves at least three times now.
But moreover, im hoping to just get this engine running right so that i can not have to spend that much money replacing a motor that is otherwise fresh!I dont know why it works but if you pull the air cleaner, let it idle and start cupping your hands over the tbi trying to choke it down. if it speeds up the motor you have a vac leak. if it dies it doesnt. Thats how I was taught.
cuz your richening the mix.... I've always liked ether, it's always a surefire easy tell.. but obviously care needs to be taken tho around exhaust, etc..
Either is much better!!! And more dangerous... short bursts, in open air, don't spray near altenator and if you have a bad spark plug wire arcing it will find it too!some prefer the carb cleaner/brake clean method... i like ether... i find it reacts better and is more noticeable... but half dozen one way, 6 the other....
