to be 100% sure find the two casting numbers on the back top corners of the engine block, right in front of the bell housing. on the drivers side of the is the family casting numbers. on the drivers side is the mouth, date, and year it was cast. get me those two numbers and i cast tell u was it is with out a doute.
its defently out of a van the trans dip stick give it away and the oil filler tube. u will need to change out the trans dip stick and the oil fill tub to the truck style, they willnt clear the hood when its closed.
yes the sm465 will work behind that 6.2, but dont use the newer needle bearing style use the older brass bushing style for the input support / bearing that goes in side the tail of the crank. u will also need to replace ur thermistat housing / cross over tub, for the truck style one, and posibley the intake. but all these parts are very ease to round up. u can rob them off of any cucv engine or m1008 / m1009. pertty much any u.s. army base should have these parts just lieing around in there scrap engine pile over there.
u may have to get a wiring harness for a late model truck tho. i have put van 6.2s in to trucks before but i usally find a late model wiring harness, guages, and gauge bezel to use too. but if nessary u could use ur stock 77 wiring harness tho, using half the engine side and the rest of the diesel side. theres a few little sensers and so on that help the engine start easer when its cold out but, like the cold start advace switch that located on the passenger side rear port on the side of the head, and the temp senders on the drivers side front head corner. oil pressure sender is the same stlye contecter as ur 77 wiring harness. mainly just if u use the 77 wiring harness then stick with the 77 temp sender and oil sender on the 6.2. so that way ur gauges will read correctly. theres really only a couple wires u need to keep to make the 6.2 work with ur 77 wiring harness and i would be glad to help u sort threw those over the phone once u where where ready to start hooking every thing up. if u have any other questions just drop me a pm.
P.S. ditch the factory glow plug controler and replace it with a ford start silenoid with a push butten style switch. much more reliable and simpler set up. and u can disect the vans wiring harness to keep the factory wiring harness part of the glow plug wires.
