Leper
So the metal would have to tear/crack/split for the pressure on it to go any further into the occupant area because the points trying to come together are limited by the strength of the other nodes, thereby strengthening the local impact area as well as diverting the pressure of the impact to the other nodes.BadDog said:Now further imagine that your cage built from triangles, connected together at nodes so it has the shape a cage should have, gets hit hard right above the driver’s door by a boulder in a hard roll. That bar will undoubtedly deform, probably flatten and bend inward a bit, BUT (and here is the key), for it to bend very far the ends of the bar must get closer together! Shortest distance between 2 points and all that. If the bar is not straight, and the length of metal remains roughly constant, the end points MUST get closer together.
Right?
EDIT*** I have quite a bit of work to do to modify my cage. Thanks BadDog.
j/k
