Found this on craigslist http://wichita.craigslist.org/pts/1136391301.html
Those 8-stud wheels only work with Bias-ply tires, right? About $67 each is $268 for the set.
Isn't the weight rating pretty low on the 8-bolts, too and only 30psi max?
I know guys that run their 8 bolt rims well down into single digits. I've also seen them with radial tires on them. I would cut down the run flats or get some pvc ones.
