those silly axels!
supersize75
gilbert az......by Phoenix
ok a week ago I decided to go 3/4 ton or 1 ton here's what I've found in Arizona so far...........
3/4 ton front rear from Moose + he's a mem =$600.00
8 lug 76 Chevy, whole truck mabey a d60 = $550.00
*front spicer/rear 14 bolt 3/4 ton=$400.00
*1 ton rear 14 bolt ff has bearing noise 4.56 gears $200.00
*3/4 ton rear 4.10 gears $300.00
*10 bolt front/14 bolt rear 3.73 gears = $700.00
3/4 ton 2wd truck no title $200.00
*3/4 ton front 410 gears 250.00
What do I do? need to make a move real quick
the project is close to the end, did I say close ha not really I want it done by Febuary /forums/images/graemlins/rotfl.gif
Well I would go with either the whole 76 if you have the room, but first check if it has a d60 or d44, and second choice is the 3/4ton's for 400.
The rest are not sets and some need work.
